13 years agoFlash Programmer error
When I program my flash memory i get an error "Resetting and Pausing Target Processor : FAILED".Is there any need to change my design?
https://www.alteraforum.com/forum/attachment.php?attachmentid=69762 Replies
Hi, you are using Quartus < 10.0 and Nios II IDE, right ?
Your are using an Altera kit, aren't you ? First, uncheck "ignore sysid" in flash programmer options. It is a bad idea to ignore sysid. Nios IDE have some troubles in programming flash. One solution is to restart Nios IDE. Maybe you try to program a flash via a wrong FPGA design (bad sysid). Maybe you have problem with reset signal. Good luck. - Altera_Forum
