21 years agoFlash Programmer bug?
I still have a problem to configure my custom board in Flash Programmer (Nios2 Evaluation Kit 1.1).
In Nios 2 1.0 my board is configuring without any error. In new version I have these error: ....# Programming flash with the FPGA configuration $SOPC_KIT_NIOS2/bin/nios2-flash-programmer --input=CamelotProject1.flash --sof=$ SOPC_KIT_NIOS2/components/Camelot_Custom_Board/system/Camelot_Custom_Board.sof - -cable='USB-Blaster [USB-0]' --base=0x00800000 24.03.2005 13:18:39 - (INFO) nios2-flash-programmer: Launching Quartus Programme r to download: C:/altera/kits/nios2/components/Camelot_Custom_Board/system/Camelot_Custom_ Board.sof Send (64) failed. Unable to synchronize with target. 24.03.2005 13:19:19 - (SEVERE) nios2-flash-programmer: Error opening target hard ware ....# Programming flash with the project $SOPC_KIT_NIOS2/bin/nios2-flash-programmer --input=cfi_flash_0.flash --sof=__NO_ SOF_PLEASE__ --cable='USB-Blaster [USB-0]' --base=0x00800000 24.03.2005 13:19:20 - (INFO) nios2-flash-programmer: SOF-download skipped. Send (8) failed. Unable to synchronize with target. 24.03.2005 13:19:51 - (SEVERE) nios2-flash-programmer: Error opening target hard ware .... My custom board has configuration controller (EPM3128) and CFI Flash (AM29LV065DU120) for configuring. I tried to add --device=num of JTAG, changed jtag_uart component in configuration design. It didn't help me. Errors the same. What is wrong? Thx.3 Replies
there are already some threads with this topic,
"--device=2" (if your fpga is second device in chain) is missing in the script, this seeems to be a bug, edit script or use your own script for programming, - Altera_Forum
I changed --device=1 in script (FPGA is first device in chain). Error the same.
Have you tried running the memtest software example on your flash? This will confirm whether or not your flash interface is functioning and is a good first step. Here are the steps that I would take:
1. Confirm that memtest works running your design. 2. Confirm that memtest works, while running out of the "target board" design (created by mk_target_board). - If either of these fails, check _first_ to see that the reset delay is implemented properly and that you have no board-level connection errors. 3. Then move on to trying the flash programmer. - Unfortunately, there's not a lot of debug information at this stage. In my experience it either works...or not, though, if I've successfully made it past steps 1 & 2, then it usually just works. Cheers, - slacker
