21 years agoFlash programmer and non CFI flash
Hi to all, does anyone knows if it's possible to use the flash programmer to program a non CFI flash memory?
21 years ago --- Quote Start --- originally posted by stonie+aug 31 2005, 02:34 am--><div class='quotetop'>quote (stonie @ aug 31 2005, 02:34 am)</div>
--- quote start ---
i am a little confused now - i thought epcs16 & 64 are supported with nios ii version 5 ?[/b]
--- quote end ---
haven't heard of an epcs64; just the epcs1, epcs4, and epcs16. the epc4, epc8, and epc16 (note that there is no 's' in their part numbers) are altera passive serial configuration devices which expose the internal flash chip's interface bus so you can hook it up to a cpu; these are not active serial epcs parts nor cfi parts, thus they are not supported. cost us three days before we figured out why our epc16 and the cfi peripheral weren't talking to each other.
<!--quotebegin-smcnutt@Aug 31 2005, 08:13 AM > it would be nice if they released the source for the slave programmer
are you referring to the source for the magic firmware_rom.hex? releasing just the protocol
used by the flash programmer would go a long way, no? --- Quote End --- That along with any tricky mojo required to make it work (things like "after the clear flash command, the programmer should reset" or whatnot) would be all that's needed.
