16 years agoFlash Programmer--MMU
Hi, I have red some posts about Flash-Programmer and the explanation of nioswiki, but I continue having some doubts about it. I have the DE2-70 FPGA with uClinux-MMU. I would like to prog...
16 years ago --- Quote Start --- Do I also have to add these offsets in custom_fpga.h or is it only necessary in these commands? --- Quote End --- Don't modify custom_fpga.h, just use the correct addresses in the commands. Drivers will use the addresses in custom_fpga.h and ioremap() them as appropriate. --- Quote Start --- Do I have to add this offset( 0xc0000000) in the command sof2flash for the EPCS? --- Quote End --- I don't know much about programming EPCS, but this is what I do to program in the FPGA configuration image:
sof2flash --activeparallel --offset=0x20000 --input=/data/nios/myfpga.sof --output=myfpga.flash
nios2-flash-programmer --base=0xe4000000 myfpga.flash --instance 1 My guess is for EPCS you just replace --activeparallel with --epcs --- Quote Start --- I don't know where to add --mmu option, could it be this place? nios2-flash-programmer --mmu --base=0x08800000 ext_flash.flash --- Quote End --- That looks right.
