20 years agoflash problem in u-boot
Hi,all
I use the Am29LV160DT flash in my cyclone custom board. and the flash used in the altera' dev board is Am29LV065D , and the size of sectors are the same , but this is not the case in Am29LV160DT , the organisation of sectors is as follow: <div class='quotetop'>QUOTE </div> --- Quote Start --- One 16 Kbyte, two 8 Kbyte, one 32 Kbyte, and thirty-one 64 Kbyte sectors (byte mode) — One 8 Kword, two 4 Kword, one 16 Kword, and thirty-one 32 Kword sectors (word mode)[/b] --- Quote End --- how to modify the source code to make it work? has anyone meet this question before? how to solve it? Any replies are highly appreciated . scut_ak4 Replies
Please see: http://forum.niosforum.com/forum/index.php...041&#entry15041 (http://forum.niosforum.com/forum/index.php?showtopic=3793&st=30&p=15041&#entry15041)
Regards, --Scott - Altera_Forum
Hi,Scott
I can use my flash now. And I do not reference the flash.c file you recommended to me, I think it more difficult and boring to modify the file . Thank you for your help anyway. - Altera_Forum
Hi, Scott
How to add your cumstom commands into the u-boot? where is the source code for the command "cp" ? and so on... Waiting for your reply. scut_ak - Altera_Forum
Hi scut_ak,
> How to add your cumstom commands into the u-boot? I started a new topic for this: http://forum.niosforum.com/forum/index.php?showtopic=3888#1 (http://forum.niosforum.com/forum/index.php?showtopic=3888#1) Regards, --Scott
