17 years agoFlash locked !
Hi all, My configuration for uClinux is : uClinux-dist-20090618.tar.bz2 nios2gcc-20080203.tar.bz2 I followed this tutorial to instanciate a "Spansion S29GL01GP 64Mx16bit (128Mbyte) ...
17 years agoThanks Hippo it works perfectly with this config.c :
------------------------------------------------------------------------# define CONFIG_DBM3C40 # if defined(CONFIG_MTD_PHYSMAP) || defined(CONFIG_MTD_PHYSMAP_MODULE) static struct mtd_partition nios2_partitions[] = {# if defined(CONFIG_DBM3C40) { .name = "jffs2_config", .size = 0x01000000, /* 16 Mo */ .offset = na_ext_flash_size-0x01000000, }, { .name = "sof_and_zimage", .size = na_ext_flash_size-0x01000000, /* 16 Mo */ .offset = 0, }# elif ... ... }; .... static struct physmap_flash_data nios2_flash_data = {# if defined(CONFIG_DBM3C40) .width = 2, /* 16 bits data bus */# elif ... ... }; ------------------------------------------------------------------------ I can successfully store any data to /dev/mtd0 like IP configuration file or some PDF files... Now I follow the tutorial "Flash Programmer" but I don't understand well the sof2flash parameter --offset in "sof in CFI, program in CFI" paragraph : # Creating .flash file for the FPGA configuration sof2flash --offset=0xc00000 --input=$SOPC_KIT_NIOS2/examples/verilog/niosII_cycloneII_2c35/standard/standard.sof --output=standard.flash For me, it only means that the size of (zImage+boot_loader), which is programmed just after this step, must be lower than 0xC00000, otherwise writing zImage or boot loader will erase some part (or full) of the SOF configuration file... Do I misunderstand the --offset parameter ? I mean it could be a "devboard-dependent" parameter for example... Thanks for your reply ! Papy
