17 years ago
Flash locked !
Hi all,
My configuration for uClinux is :
uClinux-dist-20090618.tar.bz2
nios2gcc-20080203.tar.bz2
I followed this tutorial to instanciate a "Spansion S29GL01GP 64Mx16bit (128Mbyte) Nor Flash" on a DBM3C40 devboard :
http://www.nioswiki.com/index.php?title=mtd&highlight=mtd
When I boot uClinux after a "make", here is the log concerning the flash part :
physmap platform flash device: 02000000 at 00000000
physmap-flash.0: Found 1 x16 devices at 0x0 in 8-bit bank
Amd/Fujitsu Extended Query Table at 0x0040
physmap-flash.0: CFI does not contain boot bank location. Assuming top.
number of CFI chips: 1
cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
cmdlinepart partition parsing not available
RedBoot partition parsing not available
Using physmap partition information
Creating 2 MTD partitions on "physmap-flash.0":
0x000000200000-0x000000400000 : "romfs/jffs2"
0x000000000000-0x000000200000 : "loader/kernel"
Then I try the traditionnal command to mount something :
/> mkdir /mnt/configflash
/> chmod 777 /mnt/configflash
/> mount -t jffs2 /dev/mtdblock0 /mnt/configflash
But after 1 or 2 seconds, I got these lines (automatically) :
/> MTD do_write_buffer(): software timeout
Write clean marker to block at 0x001c0000 failed: -5
Write clean marker to block at 0x001a0000 failed: -5
Write clean marker to block at 0x00180000 failed: -5
Then I tried another command to first erase all the blocks but one more time, the same error :
/> flash_eraseall -j dev/mtd0
Erasing 128 Kibyte @ 0 -- 0 % complete.MTD do_write_buffer(): software timeout
flash_eraseall: dev/mtd0: MTD write failure: Input/output error
Erasing 128 Kibyte @ 20000 -- 6 % complete.MTD do_write_buffer(): software timeout
(up to 100%)
After searching the web concerning this error, I found this :
3) "eraseall: /dev/mtd0: MTD Erase failure: Input/output error"
Possible reason: If you get this message for each block than probably write protection is on. Check the WP pin
So I decided to activate the "unlock" option in "make menuconfig" -> MTD-utils section but unfortunately it doesn't generate a "flash_unlock" executable after a "make" so I add some lines to the Makefile located in (~/nios2-linux/uClinux-dist/user/mtd-utils) :
TARGETS-$(CONFIG_USER_MTDUTILS_UNLOCK) += flash_unlock
$(ROMFSINST) -e CONFIG_USER_MTDUTILS_UNLOCK build-$(VER)/flash_unlock /bin/flash_unlock
After a "make", I successfully obtain a "flash_unlock" executable in (~/romfs/bin) but when I try this :
/> flash_unlock /dev/mtd0
/> Could not unlock MTD device: /dev/mtd0
I don't understand what is wrong in my procedure... Can the NOR Flash on DBM3C40 have a write protection (PIN) enabled by default (to the VCC) and which must be disabled manually (with pin assignements in Quartus) ?
Thanks for your help !
Papy
    I install "nios2-linux-20090730.tar" following this tutorial :
    http://www.nioswiki.com/installnios2linux
    But still the same problem :
    Sash command shell (version 1.1.1)
    /> flash_eraseall /dev/mtd0
    Erasing 128 Kibyte @ 200000 -- 100 % complete.
    Write clean marker to block at 0x00160000 failed: -5
    Write clean marker to block at 0x00140000 failed: -5
    Write clean marker to block at 0x00120000 failed: -5
    Write clean marker to block at 0x00100000 failed: -5
    Write clean marker to block at 0x000e0000 failed: -5
    Write clean marker to block at 0x000c0000 failed: -5
    Write clean marker to block at 0x000a0000 failed: -5
    Write clean marker to block at 0x00080000 failed: -5
    Write clean marker to block at 0x00060000 failed: -5
    Write clean marker to block at 0x00040000 failed: -5
    Write clean marker to block at 0x00020000 failed: -5
    Write clean marker to block at 0x00000000 failed: -5
    Write clean marker to block at 0x001e0000 failed: -5
    I don't understand what i'm doing wrong...
    Maybe the Avalon bridge shared between SRAM and CFI Flash ?
    Do I must force the SRAM pin to be disabled ?
    Papy
    The datasheet was totally wrong :
    The flash is a Spansion GL256P11FF (128Kbytes x 256 = 256M)...
    Do I must change the config.c file ?
    Please help !
    You should create an entry of your mtd map in config.c. Especially, you need to tell it the flash bus width, 8 or 16 bits. Please see flash programming for de2-70 post.
    - hippo
    Thanks Hippo it works perfectly with this config.c :
    ------------------------------------------------------------------------# define CONFIG_DBM3C40
    # if defined(CONFIG_MTD_PHYSMAP) || defined(CONFIG_MTD_PHYSMAP_MODULE)
    static struct mtd_partition nios2_partitions[] = {# if defined(CONFIG_DBM3C40)
    .name = "jffs2_config",
    .size = 0x01000000, /* 16 Mo */
    .offset = na_ext_flash_size-0x01000000,
    .name = "sof_and_zimage",
    .size = na_ext_flash_size-0x01000000, /* 16 Mo */
    .offset = 0,
    }# elif ...
    static struct physmap_flash_data nios2_flash_data = {# if defined(CONFIG_DBM3C40)
    .width = 2, /* 16 bits data bus */# elif ...
    I can successfully store any data to /dev/mtd0 like IP configuration file or some PDF files...
    Now I follow the tutorial "Flash Programmer" but I don't understand well the sof2flash parameter --offset in "sof in CFI, program in CFI" paragraph :
    # Creating .flash file for the FPGA configuration
    sof2flash --offset=0xc00000 --input=$SOPC_KIT_NIOS2/examples/verilog/niosII_cycloneII_2c35/standard/standard.sof --output=standard.flash
    For me, it only means that the size of (zImage+boot_loader), which is programmed just after this step, must be lower than 0xC00000, otherwise writing zImage or boot loader will erase some part (or full) of the SOF configuration file...
    Do I misunderstand the --offset parameter ? I mean it could be a "devboard-dependent" parameter for example...
    Thanks for your reply !
    Papy
