21 years agoFlash init from a file
I 'm using the nios IDE.
I want to init the flash with a file which contain a video Frame. Did someone has an idea to import the data from the file into the memory?2 Replies
You could use the flash programmer to do so. Select in Nios IDE: Tools->Flash Programer and in the main window check the box: "Program a file into the flash memroy" Bye, Luis - Altera_Forum
thanks, it a very easy and goog solution
