21 years agoFlash Help!
We have a board that uses 2 SST39VF160 sticks of flash. These are both 1 Meg by 16-bits. They have been configured as 1 Meg by 32-bits for a total of 4 MBytes of flash capacity. I have manage...
21 years agoCFI interface does not mean CFI compliant. The SST flash has a CFI interface, but it does not follow the CFI guidlines developed by Intel, AMD, Sharp, and Fujitsu. I have only read Intel and AMD versions.
For example, to do a CFI Query a device should send the following address and data values. Address: 0x55, Data: 0x98 in one write cycle. The SST CFI Query is done with Address: 0x5555, DATA 0xAA Address: 0x2AAA, Data 0x55 Address: 0x5555, Data 0x98 in three write cycles. In order to get the SST flash to enter query mode, I had to write VHDL driver that decoded the single write cycle used by CFI compliant flash devices and generate the SST query command. Pay attention to the data sheet, this is much easier.
