21 years ago
Flash Error
Hello everybody,
i have a new problem with the read/write into a Flash Memory. I use NiosII with the Cyclone Altera FPGA, the Quartus 5 and i use the Nios II IDE.
I compile and dowloading into a board the example called "Memory test", but when the program ask the memry with the line:
Enter the name of the CFI flash device to be opened,
or just press <enter> to open "/dev/ext_flash")
I insert
>/dev/cfi_flash_0
and the result is -ERROR: Could not open /dev/cfi_flash_0 because the line
fd = alt_flash_open_dev(flashname);
are the value &#39;0&#39;.
Can you help me, please?
gohan
1 Reply
    HI,
    let try to test change your source code form fd = alt_flash_open_dev(flashname);
    to fd = alt_flash_open_dev("/dev/cfi_flash_0");
    I have seen this one in my design. I think that uart console has some problem with CR, LF
