20 years agoFlash EPCS access problem
Hi, I'm trying to write my FPGA configuration file on its EPCS16 flash using Nios processor. The final goal is to use Uart/Usb/Ethernet communication to download the FPGA configuration file...
20 years ago --- Quote Start --- originally posted by jérôme@Apr 28 2006, 04:19 AM the problem is that each access with 'alt_write_flash'[/b] function seems to erase the entire block/sector of the flash (which represent 0x10000 datas). Is there a solution to my problem ? Thanks, Jérôme <div align='right'><{post_snapback}> (index.php?act=findpost&pid=14815) --- Quote End --- [/b] --- Quote End --- This is the nature of using most any flash device. For your situation, it makes sense to use the alt_write_flash_block() function. It won't automatically erase the flash....like alt_write_flash() does. In this way you could write to the flash in whatever data size you want and detect when a sector erase is necessary yourself. Something like the following should work if you implement it in a loop passing new "data" in with each pass:
if(new_flash_block != current_flash_block)
printf("\nFlash Block %d", new_flash_block);
alt_erase_flash_block(fd, (new_flash_block * regions->block_size),
regions->block_size);
current_flash_block = new_flash_block;
alt_write_flash_block(fd, (current_flash_block * regions->block_size),
target_addr, data, data_len); Cheers, - slacker
