16 years agoFlash doesn't work in NiosII
Hi all I want to read and write the 1MB 29LV800TE-90PFTN flash on DE2. I add a tri-state bridge and connect a CFI to it in the sopc builder and connect the pins as the demon does. 1 When...
15 years agoHi Cris,
I've tried the flash using DE2 control panel and it worked fine. I did some debugging and found out that alt_flash_open_dev couldn't find my device under the name "dev/cfi_flash" in the llist... There's only 1 device in the llist which is my EPCS controller.. And when I try using EPCS it worked fine. Is it possible that faulty setting (like timing) cause that? Or maybe the driver's fault? :S..
