16 years agoFlash doesn't work in NiosII
Hi all I want to read and write the 1MB 29LV800TE-90PFTN flash on DE2. I add a tri-state bridge and connect a CFI to it in the sopc builder and connect the pins as the demon does. 1 When...
15 years agoHi,
In these case I normally proceed in this way: - use IOWR/IORD to directly access the device: with a few wr and rd (refer to flash datasheet) you can easily readback flash device info and make sure the hardware is working properly - then you can possibly step into alt_flash_open_dev and discover if there is any problem with the driver Cris
