21 years agoFLASH ans SRAM use share bus?
Hi
The flash and sram must use the share bus? I want to ask if I can use modify the .ptf to make the flash and sram have themsleves' address signal and data signal . Thank you .1 Reply
Hi Sun2004,
You can change the pin sharing option in SOPCBuilder. Just uncheck the the sharing box in the SDRAM configuration -- then regenerate the system. Regards, --Scott
