21 years agoFlash AM29LV065D-90
I am using AM29LV065D-90 flash in a NIOSII V5.0 project that uses a custom board.
My question is since my board has a faster flash, can I use the AM29LV065D-120 instead of making a custom timing CFI interface? or am I overlooking something? Thanks in advance for you help!4 Replies
Just look into the instructions of the user interface when you add it from SOPCBuilder,
it recommends you make one by yourself . - Altera_Forum
Thank-you!! I will check it out!!
I'm using -120 revision and it works OK.
Hi Brandon,
> can I use the AM29LV065D-120 instead of making a custom > timing CFI interface? or am I overlooking something? Yes. The cycle time just won't be as fast. Unless your application is flash-intensive, you probably won't notice the difference. Regards, --Scott
