20 years agoFive days till grad. project delivery
Hello all.. Last 5 days to go .. and i will deliver my graduation project .. and still i have some troubles that i cant solve.. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad....
20 years agoTarek,
As Espian mentions, you should refer to the CI User's Guide, especially the builtin functions section. If the cross compiler for uCLinux retains support for these builtins, then your answer is yes. You might want to try to compile the simple bitswap example as a uCLinux user-level application, just to see if it will work. Cheers, - slacker
