20 years agoFirst time using lwIP
Hello, I´ve started using lwIP this week. I tried the Webserver example and it worked fine (I can access the webpage from my browser =). Well... I read the code many times and couldn´t understa...
20 years agoIt looks like you're trying to LWIP's "raw" and/or stand alone API. This is a _callback_-based API. You need to, at a bare minimum, read through the raw_api.txt file.
In addition, it makes sense to take a look at the TCP echo server, included with the distribution on this website, and use it as a basis for starting your own application. Once you have it working, you'll have much more luck stripping out what you don't feel you need. Cheers, - slacker
