20 years agoFirst time using lwIP
Hello, I´ve started using lwIP this week. I tried the Webserver example and it worked fine (I can access the webpage from my browser =). Well... I read the code many times and couldn´t understa...
20 years agoThanks for the pdf.
I can start the server now, but I still can't send and receive messages. How do I use the tcp_accept anyway? I tried something like pcb = tcp_new(); tcp_bind(pcb, IP_ADDR_ANY, 80); pcb = tcp_listen(pcb); tcp_accept(pcb, ERR_OK); while(1) { printf("\nI will send"); getchar(); tcp_write(pcb, "lalala", sizeof("lalala"), 0); } Well.... then my client can connect, but it won´t receive anything. If I do something like: tcp_accept(pcb, envia); and create the function "envia" like this: static err_t envia(void *arg, struct tcp_pcb *pcb, err_t err) { int i; for(i = 0; i < 5; i++) { printf("\nVou enviar"); getchar(); tcp_write(pcb, "lalala", sizeof("lalala"), 0); } return ERR_OK; } It will send the "lalala" five times when it reaches the "return". But I want to use the tcp_write inside the main How do I do that? Thanks
