20 years agoFirst time using lwIP
Hello, I´ve started using lwIP this week. I tried the Webserver example and it worked fine (I can access the webpage from my browser =). Well... I read the code many times and couldn´t understa...
20 years agoHi HoffPistolao,
you should first download this pdf-file: http://www.sics.se/~adam/lwip/doc/lwip.pdf (http://www.sics.se/~adam/lwip/doc/lwip.pdf) that is documentation on the lwip-stack. I tried to modify without reading it to but it really doesn't work. They told on this forum that I first should try to understand it. That's what I did en that way you can really develop something usefull. Good luck..... Cheers, Danny
