20 years agoFireFly + LWIP + Opencores EMAC problems
Hi All, I'm trying to establish a TCP-connection between Firefly dev.Kit (client) and my laptop (server). I'm using Microtronix Firefly dev.kit, opencores ethernet EMAC (microtronix als...
19 years agoHi Sam,
I have solved the problem by fixing the code of the network_utilities.c file of lwip_webserver example. The updated code listing of functions get_ip_addr and dhcp_timeout_task are listed below. Updated parts of the file are between "/********************/" -rows. The bug was that if static ip was used there wasn't any eth adapter working as default eth-interface. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/ohmy.gif Regards, CoolMan ----------------------UPDATED CODE START------------------------------- int get_ip_addr(alt_lwip_dev* lwip_dev, struct ip_addr* ipaddr, struct ip_addr* netmask, struct ip_addr* gw, int* use_dhcp) { int ret_code = 0; if (!strcmp(lwip_dev->name, "/dev/" LWIP_DEFAULT_IF)) {# if LWIP_DHCP == 1 *use_dhcp = 1; /* * If we are telling LWIP to attempt DHCP, all that is needed is to save * the the LWIP device in question to a the global netif "adapter"; the * DHCP timeout task will then querry this device to see whether an IP * address has been set. * * If we are not attempting DHCP, static network settings are assigned here * and we go on our merry way. */ adapter = lwip_dev->netif; # ifdef LCD_DISPLAY_NAME /* Clear the LCD screen */ fprintf(lcdDevice, "\x1b"); fprintf(lcdDevice, "[2J"); fprintf(lcdDevice, "Using DHCP to\nfind IP Addr");# endif /* LCD_DISPLAY_NAME */ printf("Using DHCP to find an IP Address\n"); # else /***********************************************************/ //TOP 7.2.2007 adapter = lwip_dev->netif; /***********************************************************/ IP4_ADDR(ipaddr, IPADDR0,IPADDR1,IPADDR2,IPADDR3); IP4_ADDR(gw, GWADDR0,GWADDR1,GWADDR2,GWADDR3); IP4_ADDR(netmask, MSKADDR0,MSKADDR1,MSKADDR2,MSKADDR3); *use_dhcp = 0; printf("Static IP Address is %d.%d.%d.%d\n", ip4_addr1(ipaddr), ip4_addr2(ipaddr), ip4_addr3(ipaddr), ip4_addr4(ipaddr)); /***********************************************************/ //TOP 7.2.2007 netif_set_default(adapter); //TOP 7.2.2007 netif_set_up(adapter); /***********************************************************/ # ifdef LCD_DISPLAY_NAME /* Clear the LCD screen */ fprintf(lcdDevice, "\x1b"); fprintf(lcdDevice, "[2J"); fprintf(lcdDevice, "Static IP Addr\n %d.%d.%d.%d", ip4_addr1(ipaddr), ip4_addr2(ipaddr), ip4_addr3(ipaddr), ip4_addr4(ipaddr));# endif /* LCD_DISPLAY_NAME */ # endif /* LWIP_DHCP */ ret_code = 1; } return ret_code; } /* * dhcp_timeout_task() * * This LWIP-called routine is responsible for checking to see whether DHCP * was sucessful. Here we check to see whether a timeout (120 seconds in this * case) has elapsed. If so, display an error, assign a static address, and * bail out. If not, continue checking for DHCP success and bail out once * a DHCP address assignment is complete. * * This routine also displays the assigned IP address to the user (via STDOUT * and, if equipped, LCD screen. * * Note: LCD_DISPLAY_NAME is defined in user.h to be the LCD interface for * the "standard" example design. */# if LWIP_DHCP == 1 void dhcp_timeout_task() { static int have_address = 0, timeout_dhcp = 0; struct ip_addr ipaddr, netmask, gw; if (!have_address) { /* * For demo purposes we need to use DHCP to allocate an IP Address * and LWIP had no mechanism to tell us one is allocated. Wait two * minutes if we don't have one we use a static IP address */ if(timeout_dhcp < 120) { timeout_dhcp++; if (!ip_addr_isany(&adapter->ip_addr)) { have_address = 1; printf("Assigned IP Address is %d.%d.%d.%d\n\n", ip4_addr1(&adapter->ip_addr), ip4_addr2(&adapter->ip_addr), ip4_addr3(&adapter->ip_addr), ip4_addr4(&adapter->ip_addr)); # ifdef LCD_DISPLAY_NAME lcdDevice = fopen(LCD_DISPLAY_NAME, "w"); /* Clear screen */ fprintf(lcdDevice, "\x1b"); fprintf(lcdDevice, "[2J"); fprintf(lcdDevice, "DHCP IP Addr is \n %d.%d.%d.%d", ip4_addr1(&adapter->ip_addr), ip4_addr2(&adapter->ip_addr), ip4_addr3(&adapter->ip_addr), ip4_addr4(&adapter->ip_addr)); fclose(lcdDevice);# endif /* LCD_DISPLAY_NAME */ } } /* * You're in a bit of trouble if this happens, you could assign a static * IP address but how do we choose it? */ else { dhcp_stop(adapter); IP4_ADDR(&ipaddr, IPADDR0,IPADDR1,IPADDR2,IPADDR3); IP4_ADDR(&gw, GWADDR0,GWADDR1,GWADDR2,GWADDR3); IP4_ADDR(&netmask, MSKADDR0,MSKADDR1,MSKADDR2,MSKADDR3); netif_set_addr( adapter,&ipaddr, &netmask, &gw); have_address = 1; printf("DHCP Failed to assign an IP Address\n"); printf("Using static address: %d.%d.%d.%d\n\n", ip4_addr1(&adapter->ip_addr), ip4_addr2(&adapter->ip_addr), ip4_addr3(&adapter->ip_addr), ip4_addr4(&adapter->ip_addr)); /***********************************************************/ //TOP 7.2.2007 netif_set_default(adapter); //TOP 7.2.2007 netif_set_up(adapter); /***********************************************************/ # ifdef LCD_DISPLAY_NAME lcdDevice = fopen(LCD_DISPLAY_NAME, "w"); /* Clear the LCD screen */ fprintf(lcdDevice, "\x1b"); fprintf(lcdDevice, "[2J"); fprintf(lcdDevice, "DHCP Failed using\n %d.%d.%d.%d", ip4_addr1(&adapter->ip_addr), ip4_addr2(&adapter->ip_addr), ip4_addr3(&adapter->ip_addr), ip4_addr4(&adapter->ip_addr)); fclose(lcdDevice);# endif /* LCD_DISPLAY_NAME */ } } }# endif /* LWIP_DHCP */ ----------------------UPDATED CODE END------------------------------ --- Quote Start --- originally posted by samlittle@Jan 19 2007, 04:26 AM hi,i have the same situation. if i turn on dhcp that will be fine, except getting failure from dhcp server. so, i use static ip and trun off dhcp but it doesn't work. i also use microtronix ethernet-usb expansion board and mircotronix lwip.
does anyone can help me to solve this?
best regards,
sam
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=20711)
--- quote end ---
--- Quote End ---
