20 years ago
FireFly + LWIP + Opencores EMAC problems
Hi All,
I'm trying to establish a TCP-connection between Firefly dev.Kit (client) and my laptop (server). I'm using Microtronix Firefly dev.kit, opencores ethernet EMAC (microtronix also) and LWIP (microtronix also). I have gonfigured the example software project lwip_web_server so that only static IP address option is ON and the DHCP is OFF. The static IP address for Firefly-module is configured succesfully but there is a problem to establish a tcp-socket connection between Firefly-module and laptop.
I have sniffed ETH traffic between client and server and I noticed that the client finds the server and sends only TCP SYN -messages. The server replies with SYN-ACK messages, but the client doesn't get those messages because it doesn't anwer to those messages with ACK-messages. It looks like the client can't receive any messages.
CoolMan
    I have the same situation. If i turn on DHCP that will be fine, except getting failure from DHCP server. So, i use static IP and trun off DHCP but it doesn't work. I also use Microtronix Ethernet-USB expansion board and Mircotronix LWIP.
    Does anyone can help me to solve this?
    Sam
    Hi Sam,
    I have solved the problem by fixing the code of the network_utilities.c file of lwip_webserver example. The updated code listing of functions get_ip_addr and dhcp_timeout_task are listed below. Updated parts of the file are between "/********************/" -rows.
    The bug was that if static ip was used there wasn&#39;t any eth adapter working as default eth-interface. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/ohmy.gif
    CoolMan
    ----------------------UPDATED CODE START-------------------------------
    int get_ip_addr(alt_lwip_dev* lwip_dev, struct ip_addr* ipaddr,
    struct ip_addr* netmask, struct ip_addr* gw,
    int* use_dhcp)
    int ret_code = 0;
    if (!strcmp(lwip_dev->name, "/dev/" LWIP_DEFAULT_IF))
    {# if LWIP_DHCP == 1
    *use_dhcp = 1;
    * If we are telling LWIP to attempt DHCP, all that is needed is to save
    * the the LWIP device in question to a the global netif "adapter"; the
    * DHCP timeout task will then querry this device to see whether an IP
    * address has been set.
    * If we are not attempting DHCP, static network settings are assigned here
    * and we go on our merry way.
    adapter = lwip_dev->netif;
    # ifdef LCD_DISPLAY_NAME
    /* Clear the LCD screen */
    fprintf(lcdDevice, "\x1b");
    fprintf(lcdDevice, "[2J");
    fprintf(lcdDevice, "Using DHCP to\nfind IP Addr");# endif /* LCD_DISPLAY_NAME */
    printf("Using DHCP to find an IP Address\n");
    # else
    //TOP 7.2.2007
    IP4_ADDR(ipaddr, IPADDR0,IPADDR1,IPADDR2,IPADDR3);
    IP4_ADDR(gw, GWADDR0,GWADDR1,GWADDR2,GWADDR3);
    IP4_ADDR(netmask, MSKADDR0,MSKADDR1,MSKADDR2,MSKADDR3);
    *use_dhcp = 0;
    printf("Static IP Address is %d.%d.%d.%d\n",
    ip4_addr1(ipaddr),
    ip4_addr2(ipaddr),
    ip4_addr3(ipaddr),
    ip4_addr4(ipaddr));
    //TOP 7.2.2007
    netif_set_default(adapter);
    //TOP 7.2.2007
    netif_set_up(adapter);
    fprintf(lcdDevice, "Static IP Addr\n %d.%d.%d.%d",
    ip4_addr1(ipaddr),
    ip4_addr2(ipaddr),
    ip4_addr3(ipaddr),
    ip4_addr4(ipaddr));# endif /* LCD_DISPLAY_NAME */
    # endif /* LWIP_DHCP */
    ret_code = 1;
    return ret_code;
    * dhcp_timeout_task()
    * This LWIP-called routine is responsible for checking to see whether DHCP
    * was sucessful. Here we check to see whether a timeout (120 seconds in this
    * case) has elapsed. If so, display an error, assign a static address, and
    * bail out. If not, continue checking for DHCP success and bail out once
    * a DHCP address assignment is complete.
    * This routine also displays the assigned IP address to the user (via STDOUT
    * and, if equipped, LCD screen.
    * Note: LCD_DISPLAY_NAME is defined in user.h to be the LCD interface for
    * the "standard" example design.
    */# if LWIP_DHCP == 1
    void dhcp_timeout_task()
    static int have_address = 0, timeout_dhcp = 0;
    struct ip_addr ipaddr, netmask, gw;
    if (!have_address)
    * For demo purposes we need to use DHCP to allocate an IP Address
    * and LWIP had no mechanism to tell us one is allocated. Wait two
    * minutes if we don&#39;t have one we use a static IP address
    if(timeout_dhcp < 120)
    timeout_dhcp++;
    if (!ip_addr_isany(&adapter->ip_addr))
    have_address = 1;
    printf("Assigned IP Address is %d.%d.%d.%d\n\n",
    ip4_addr1(&adapter->ip_addr),
    ip4_addr2(&adapter->ip_addr),
    ip4_addr3(&adapter->ip_addr),
    ip4_addr4(&adapter->ip_addr));
    lcdDevice = fopen(LCD_DISPLAY_NAME, "w");
    /* Clear screen */
    fprintf(lcdDevice, "DHCP IP Addr is \n %d.%d.%d.%d",
    fclose(lcdDevice);# endif /* LCD_DISPLAY_NAME */
    * You&#39;re in a bit of trouble if this happens, you could assign a static
    * IP address but how do we choose it?
    else
    dhcp_stop(adapter);
    IP4_ADDR(&ipaddr, IPADDR0,IPADDR1,IPADDR2,IPADDR3);
    IP4_ADDR(&gw, GWADDR0,GWADDR1,GWADDR2,GWADDR3);
    IP4_ADDR(&netmask, MSKADDR0,MSKADDR1,MSKADDR2,MSKADDR3);
    netif_set_addr( adapter,&ipaddr, &netmask, &gw);
    have_address = 1;
    printf("DHCP Failed to assign an IP Address\n");
    printf("Using static address: %d.%d.%d.%d\n\n",
    //TOP 7.2.2007
    //TOP 7.2.2007
    fprintf(lcdDevice, "DHCP Failed using\n %d.%d.%d.%d",
    }# endif /* LWIP_DHCP */
    ----------------------UPDATED CODE END------------------------------
    --- Quote Start ---
    originally posted by samlittle@Jan 19 2007, 04:26 AM
    hi,
    i have the same situation. if i turn on dhcp that will be fine, except getting failure from dhcp server. so, i use static ip and trun off dhcp but it doesn&#39;t work. i also use microtronix ethernet-usb expansion board and mircotronix lwip.
    does anyone can help me to solve this?
    best regards,
    sam
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=20711)
    --- quote end ---
    --- Quote End ---
