12 years agoFilling in cyg_flash_devtab[] array
Does anybody know when and how cyg_flash_devtab[] array is filled in? I see &(syg_flashdevtab[0]) == &syg_flashdevtab_end and syg_flashdevtab[0].num_block_infos < 0 whereas SYGHWR_IO_FLASH_DEVICE == ...
12 years agoIt's just that this is an Altera forum, and the eCos section here is more specifically about the Nios II port of eCos. If you are using a PowerPC board you'll probably have more luck on a more generic eCos forum or mailing list, or maybe on a PowerPC forum.
