22 years agoFilesystem for compact flash
I want to install a fat filesystem on the compact flash. I am using the stratix evaluation board. Can somebody tell me if i can use the files existing in the microtronix linux for this purpose. ...
22 years agoHi,
If you are using Linux, sure you can use FAT. Since the Compactflash from Altera is pre-formated as FAT, you only need to enable FAT support in kernel configuration. I tried this on Stratix, it worked fine.
