20 years agoFile upload with boa
Hi, I'm trying to upload the uClinux Kernel to the Nios RAM via http, and then to write it to the flash. I see that the web server boa don't support the method post for non-script....
20 years ago<div class='quotetop'>QUOTE </div>
--- Quote Start --- I use now another web server: goahead.[/b] --- Quote End --- Hi steppa, did you compile the source code in windows? I'll be grateful if you share some idea about. Warm Regards
