17 years agoFIFO - Transfer of data
IS there anyway to transfer data in\out of the SOPC FIFO instantiated core to logic outside of the SOPC sytem without using a NIOS ? It seems from the datasheets of the core that the only way to acce...
16 years agooops I keep forgetting to enable jscript....
I reformatted my original post so hopefully it makes more sense. There are various port types you can use in SOPC Builder, masters and slaves for MM, sinks and sources for ST, and export for exposing signals to the top. I'm not sure what you are trying to do so I can't make a recommendation on whether MM or ST is more suitable so I would look at the Avalon specification on the SOPC Builder literature page and determine which interface type is more appropriate for your FIFO component.
