16 years agoFft In Sopc
Guyz please help , if u have an idea. Uptil now i made a 64 point FFT using megacore and added it to the sopc as a new component but there are a lot of signals and so it gives me an error when ...
15 years agoHI Marlon :
i think swapping bytes come from using SGDMA (when it read and write data on memory), So you should swap bytes in input and output of FFT. i think it is not good way to swap bytes in software (by using pointers). maybe it spends a time from Nios II. it is better to try swapping bytes in hardware, by swapping the signal in (fft_avalon_wraper.v) file. change the connect of signal to match your swapping. for example, try to do that in (fft_avalon_wraper.v) file: wire [15 : 0] temp_input;
assign temp_input[15: 8] = sink_real[7 : 0]; assign temp_input[7 : 0] = sink_real[15 : 8]; temp_input is the input of FFT module. [/B][/B] you should do the same for output.
