16 years agoFft In Sopc
Guyz please help , if u have an idea. Uptil now i made a 64 point FFT using megacore and added it to the sopc as a new component but there are a lot of signals and so it gives me an error when ...
16 years agoyou can use this one:
--- Quote Start --- module fft_avalon_wraper ( input clk, input reset_n, input mm_writedate, input mm_write, input sink_valid, input sink_sop, input sink_eop, input [31 : 0] sink_data, input sink_error, input source_ready, output sink_ready, output source_error, output source_sop, output source_eop, output source_valid, output [39 : 0] source_data ); reg inverse; always@(posedge clk) begin if(mm_write) inverse = mm_writedate; end assign source_data[39 : 38] = 2'b0; your_fft_from_megawizard fft_inst ( clk, reset_n, inverse, sink_valid, sink_sop, sink_eop, sink_data[31 : 16], sink_data[15 : 0], sink_error, source_ready, sink_ready, source_error, source_sop, source_eop, source_valid, source_data[37 : 32], source_data[31 : 16], source_data[15 : 0] ); endmodule --- Quote End --- your_fft_from_megawizard is your fft module, configure it's interface as streaming. this wraper contains 3 avalon interface: streaming sink and streaming source: data input and output, read latency = 0, 8 bits per symbol, use 2 sgdma-s for connecting them to you memory, data adapters may needed. memory map: control the inverse signal of you fft, set it's addressing as NATIVE. take attention to the width of sink_data and source_data, you may modify them and their connection to sink_real, sink_imag, source_exp, source_real, source_imag due to your own fft module. you can refer to fft megacore function user guide.pdf, which contains detailed information about the interface.
