20 years agoFAT on Compact Flash
Hello, I just found how to implement FAT file System on my Compact Flash without any OS, on the 1C20 Evaluation Kit and I think anybody is interresed by this subject. Sorry for my en...
20 years agoHi to all,
i've no problem with Compact flash (sandisk) 16 Mo, 32 Mo,128 Mo and 256 Mo. But with an 2 Go there is somme problem, but i've some problem on another application with this 2Go card, i think the card is bad perhaps. If Dosfs is too slow, ok if there is a better idea... http://elm-chan.org/fsw/ff/00index_e.html (http://elm-chan.org/fsw/ff/00index_e.html) is good...and there is a subjet on mmc/sd card. For me, i've no time at this moment to continue this projet, actually i work to implement an pci bridge in vhdl (from opencore) in a nios project. Normally in 2007, i've to do a new projet to implement Dos File System, with an SD/MMC card in SPI mode, i think i will see a better solution. Thank you to continue this project.... O DESPONT NB: the page on jack Dobiash is good too : http://home.teleport.com/~brainy/fat16.htm (http://home.teleport.com/~brainy/fat16.htm)
