21 years agoFAT filesystem for compact flash
I am using a stratix evaluation board. I wanted to create a FAT filesystems on the compact flash onboard. Can i do this using the present uclinux port . If so what are the steps. Tell me t...
21 years agoreju_r,
> Even a FAT systems without any OS wouls do. If you only need read access to a FAT filesystem, you could try the u-boot boot monitor with FAT support enabled. You could also check if Redboot supports FAT. Regards, --Scott
