21 years agoFast data access with Nios II ?
I have tried to quickly access external data with a custom instruction. After I have realized, that 1 cycle-custom-instructions cannot have external connections, I implemented a 2-cycle custom instru...
21 years agoLet me clear up a few things.
There are two types of custom instructions: - combinatorial - multi-cycle The term register is ambiguous because you can't tell if I'm talking about one of the CPU registers in the register file or just a basic storage device. Let me use flop for the later. The combinatorial instructions can't write any flops and can't stall the CPU. We don't allow it to write any flops because the Nios II/s and Nios II/f might speculatively execute an instruction (mainly due to branch mispredictions) but then kill it later in the pipeline. Notice that I didn't say combinatorial instructions can't read from flops or can't read from external inputs. If you really have some data available for the CPU to read that is guaranteed to always be present (i.e. never needs to stall), I don't see why you can't use a combinatorial custom instruction to read it. Writing it is not allowed because of the speculative execution issue. The multi-cycle custom instructions execute later in the pipeline so are never speculatively executed. This allows them to read or write any flop or external values. They can also stall the pipeline as needed. These instructions always stall the pipeline for at least one cycle to avoid slow paths from the custom instruction into the pipeline (stall logic and register write data). As you've noticed, if you setup your custom instruction to take N cycles to execute, the pipeline always adds one more cycle to this. The pipeline registers the result data provided by your custom instruction before muxing it with the other sources of register write data (e.g. ALU, load data, multiply result, etc). You are allowed to have a multi-cycle custom instruction with N=1 although I seem to remember a bogus error/warning from the custom instruction wizard in SOPC Builder if you try to do this. This should be fixed in Nios II 1.1. So, in summary, here's the best you can do: - Reading data from register/external input that is always ready: Implementation: Combinatorial custom instruction Performance: 1 cycle per instruction - Reading data from register/external input that might not always be ready: Implementation: variable-latency multi-cycle custom instruction Performance: Number of cycles of latency + 1 more - Writing data to register/external input: Implementation: fixed-latency multi-cycle custom instruction setup for one cycle Performance: 2 cycles per instruction Be careful if you have a multicycle custom instruction writing a flop/external output and a combinatorial custom instruction reading the same data. The combinatorial custom instruction won't read the latest value because it executes in an earlier pipeline stage than the multicycle custom instruction. If you have this situation, you also should use a multicycle custom instruction (with a fixed latency of 1 cycle) to read values. This will cut down your read performance to 2 cycles per instruction. I hope this helps!
