19 years agoFailure to allocate memory
I've got a 2.6.16 based uClinux Kernel running on my Nios2 custom hardware. I've compiled "telnetd" into Busybox and Dropbear SSH. I've tried to bring down the size of the Kernel to as li...
19 years agoIf you use server in busybox, it will take up a lot of memory.
You should use stand-alone servers. If you use the simple init and sash in uClinux-dist, you will have more memory available than using all in busybox.
