12 years ago
Failed to program flash
Hello everyone,
Sorry about my poor english, i've developped a FPGA board which has a SST39VF6401B (Microchip flash), i'm using SOPC to configure the FPGA. I use Nios II to program flash (only blink leds) but when program flash, the only error is "no cfi table found". I also run program on the SD RAM to make sure my FPGA, RAM and JTAG still fine.
Can anyone solve this problem or any suggestions?
Thank you very much and best regards
    If it works with onchip ram, there's definitely a problem with sdram configuration or with shared bus.
    --- Quote Start ---
    --- Quote End ---
    Hi Cris72,
    Thanks for your reply,
    I'm working on the project with Judau and config for this project.
    About hardware:
    + I'm using the sdram 8Mbyte of Micron and using sdram controller core and check in (Share pins via tristate bridge, Tristate bridge selection i had chossed the tri_state_bridge which handle the cfi_flash). About timing of sdram controller i setting default.
    + I'm using the cfi_flash S29AL032D of Spainsion and using the CFI controller core. Address width is 21, Data width is 16 because cfi_flash sharing data and address with sdram (limited i/o pin in hardware). About the timing 40-160-40ns. And in the schematic WP#, RY/BY# pull up 4k7 resitor to 3V3, and pin 47 BYTE# (F_MODE) control by FPGA (assign F_MODE = 1'b1;)
    And i had made on chip ram 24KB for testing.
    The reset_vector using cfi_flash.
    The exception_vector using sdram.
    The nios ii config .text, .rodata, .rwdata, heap and stack i setting at sdram.
    My problem now is when i set .text, .rodata, .rwdata, heap and stack i setting at on chip ram and programing to cfi_flash complete after reset the LED test blink ok but when i set .text, .rodata, .rwdata, heap and stack i setting at sdram, the nios not working.
    Can you help me!
    Thanks and Regard!.
    Q.Cuong.
