13 years agoFailed to program flash
Hello everyone, Sorry about my poor english, i've developped a FPGA board which has a SST39VF6401B (Microchip flash), i'm using SOPC to configure the FPGA. I use Nios II to program flash (only ...
13 years ago --- Quote Start --- If it works with onchip ram, there's definitely a problem with sdram configuration or with shared bus. --- Quote End --- Hi Cris72, Thanks for your reply, I'm working on the project with Judau and config for this project. About hardware: + I'm using the sdram 8Mbyte of Micron and using sdram controller core and check in (Share pins via tristate bridge, Tristate bridge selection i had chossed the tri_state_bridge which handle the cfi_flash). About timing of sdram controller i setting default. + I'm using the cfi_flash S29AL032D of Spainsion and using the CFI controller core. Address width is 21, Data width is 16 because cfi_flash sharing data and address with sdram (limited i/o pin in hardware). About the timing 40-160-40ns. And in the schematic WP#, RY/BY# pull up 4k7 resitor to 3V3, and pin 47 BYTE# (F_MODE) control by FPGA (assign F_MODE = 1'b1;) And i had made on chip ram 24KB for testing. The reset_vector using cfi_flash. The exception_vector using sdram. The nios ii config .text, .rodata, .rwdata, heap and stack i setting at sdram. My problem now is when i set .text, .rodata, .rwdata, heap and stack i setting at on chip ram and programing to cfi_flash complete after reset the LED test blink ok but when i set .text, .rodata, .rwdata, heap and stack i setting at sdram, the nios not working. Can you help me! Thanks and Regard!. Q.Cuong.
