13 years agoFailed to program flash
Hello everyone, Sorry about my poor english, i've developped a FPGA board which has a SST39VF6401B (Microchip flash), i'm using SOPC to configure the FPGA. I use Nios II to program flash (only ...
13 years agoI believe you have some problem with the bootloader.
I guess you are using the standard bootloader provided by Altera; then you should have a boot_loader_cfi.srec file referenced somewhere in your project. Also check the Advanced.Hal.Linker parameters in BSP.
