13 years agoFailed to program flash
Hello everyone, Sorry about my poor english, i've developped a FPGA board which has a SST39VF6401B (Microchip flash), i'm using SOPC to configure the FPGA. I use Nios II to program flash (only ...
13 years agoDoes Nios reset vector point to flash?
Please also check if the problem is only with Nios boot. I mean, check if fpga gets correctly configured after you press reset button. Do you use the same flash memory for configuration and Nios program?
