16 years ago
Fail to restart program after poweroff and poweron
Best wishes and happy new year for all!!
I have a problem on rebooting my project.
The program runs ok when flashed on my nios ii system board (is a custom board consist of an cyclone ii fpga, sdram, epcs flash device and an lcd), but when I power off and then power on the board the program does not start any more!
I use an EPCS4 4Mbit flash connected to my NIOS II.
On SOPC builder I put 0x0 as starting address of my EPCS4 flash device connected and the reset vector on cpu also to starts on 0x0 and the exception vector is on sdram with offset 0x20.
I flashed the system and the program (sof and elf files) using flash programmer from Eclipse Ganymede menu!
I do not know if that is enough or have to do more actions?
Do I have to add more files? (.pof for example)?
Can you please help ?
Thanks in advance!
    Doesn't the EPCS64 have a different footprint than the EPCS4?
    Jake
    Yes its a SOIC16 but is ok for the board.
    The curent chip is SOIC8.
    but until the new flash chip arrives, I tried to put the hardware image only to flash using AS programming and now the board has the nios ii system present even power off and then on the board.
    Lets suppose that I want now to add the only software, is possible to add partially?
    Finally I put an EPCS16. The problem insists!!!! I am doing something wrong!!!
    Can you post any and all error messages you are receiving?
    Jake
    This is the script generated by Eclipse nios Flash programmer.
    If I launch it gives the following.
    Is the quartus_cpf --no_banner --convert --device=EPCS128....referred in the first lines ok ? I use an EPCS16 ?
    After the script finishes I press reset and programm is running ok.
    But if I cycle power not starts any more. I noticed also that after cycle power nios2 is absent!
    Thank you for your time!
    /cygdrive/d/ep2c8/script
    [NiosII EDS]$ ./flash_programmer.sh
    Jan 19, 2010 1:47:29 AM - (FINE) sof2flash: Starting
    Info: *******************************************************************
    Info: Running Quartus II Convert_programming_file
    Info: Command: quartus_cpf --no_banner --convert --device=EPCS128 --option=D:/ep
    2c8/flash/2c8_TRH_epcs.opt D:/ep2c8/2c8_TRH.sof D:/ep2c8/flash/2c8_TRH_epcs.pof
    Info: Quartus II Convert_programming_file was successful. 0 errors, 0 warnings
    Info: Peak virtual memory: 69 megabytes
    Info: Processing ended: Tue Jan 19 01:47:31 2010
    Info: Elapsed time: 00:00:01
    Info: Total CPU time (on all processors): 00:00:01
    Info: Command: quartus_cpf --no_banner --convert D:/ep2c8/flash/2c8_TRH_epcs.pof
    D:/ep2c8/flash/2c8_TRH_epcs.rpd
    Info: Peak virtual memory: 68 megabytes
    Info: Processing ended: Tue Jan 19 01:47:34 2010
    Info: Elapsed time: 00:00:02
    Info: Total CPU time (on all processors): 00:00:02
    Jan 19, 2010 1:47:35 AM - (FINE) sof2flash: Done
    Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
    Resetting and pausing target processor: OK
    Reading System ID at address 0x00001898: verified
    Processor data bus width is 32 bits
    Looking for EPCS registers at address 0x00000000 (with 32bit alignment)
    Initial values: 0001703A 04C00074 9801483A 9CFFF804 983FFD1E 0000203A
    Not here: reserved fields are non-zero
    Looking for EPCS registers at address 0x00000100 (with 32bit alignment)
    Initial values: 92400237 4A40100C 483FFD26 90000135 92400237 4A40200C
    Looking for EPCS registers at address 0x00000200 (with 32bit alignment)
    Initial values: 00000000 00000000 00000260 00000000 00000000 00000001
    Valid registers found
    EPCS signature is 0x14
    EPCS identifier is 0x202015
    Using EPCS size information from section [EPCS-202015]
    Device size is 2MByte (16Mbit)
    Erase regions are:
    offset 0: 32 x 64K
    EPCS status is 0x00
    : Checksumming existing contents
    00000000 : Verifying existing contents
    00000000 : Needs erase then program
    00010000 : Verifying existing contents
    00010000 : Needs erase then program
    00020000 : Verifying existing contents
    00020000 : Needs erase then program
    00000000 : Reading existing contents
    00010000 : Reading existing contents
    00020000 : Reading existing contents
    Checksummed/read 49kB in 1.1s
    00000000 ( 0%): Erasing
    00010000 (33%): Erasing
    00020000 (66%): Erasing
    Erased 192kB in 1.9s (101.0kB/s)
    00000000 ( 0%): Programming
    00010000 (33%): Programming
    00020000 (66%): Programming
    Programmed 144KB +48KB in 4.5s (42.6KB/s)
    Did not attempt to verify device contents
    Leaving target processor paused
    Jan 19, 2010 1:47:45 AM - (INFO) elf2flash: args = --input=D:/ep2c8/software/THP
    /THP.elf --output=D:/ep2c8/flash/THP_epcs.flash --epcs --after=D:/ep2c8/flash/2c
    8_TRH_epcs.flash --verbose
    Jan 19, 2010 1:47:45 AM - (FINE) elf2flash: Starting
    Jan 19, 2010 1:47:45 AM - (FINER) elf2flash: Program Record: 71264 bytes destine
    d for 0x2000020
    Jan 19, 2010 1:47:45 AM - (FINER) elf2flash: Start Record: 20001c4
    Jan 19, 2010 1:47:45 AM - (FINE) elf2flash: Done
    Erase regions are:
    offset 0: 32 x 64K
    EPCS status is 0x00
    00030000 : Verifying existing contents
    00030000 : Needs erase then program
    00030000 : Reading existing contents
    Checksummed/read 59kB in 1.5s
    00020000 ( 0%): Erasing
    00030000 (50%): Erasing
    Erased 128kB in 1.3s (98.4kB/s)
    00020000 ( 0%): Programming
    00030000 (50%): Programming
    Programmed 70KB +58KB in 2.0s (64.0KB/s)
    Unfortunately I see in the forum that other people had problems with epcs boot due to a Quartus ii 9.1 version.
    I searched altera's site but I did not found a patch that fixes the problem.
    I cannot find also the 9.0 version of quartus to reinstall.
    I tried to communicate with altera for support but I didnt find the way. I am doing cycles in the site.
    Anyway I am a student and I do my thesis on nios2.
    I am really very sorry because I cannot conclude!! I lost more than a month reading and searching for the boot problem. it took less time the nios development and the software than the boot!
    Maybe I am wrong but I think altera has not a good policy!!!!!!!!!!!!!!!!!!!
    They should have already issue free for public and easy to download the patch.
    I am really very sorry for all my lost time!!!!!
    --- Quote Start ---
    I think he's using the NIOS II flash programmer to program the EPCS device. You give it the SOF file and it does the conversion for you.
    Jake
    --- Quote End ---
    I think he's right.
    A few days ago it was published by Altera the service pack for Quartus ii 9.1 web and Nios IDE!
    I installed it and everything works now ok!!
