16 years agoFail to restart program after poweroff and poweron
Best wishes and happy new year for all!! I have a problem on rebooting my project. The program runs ok when flashed on my nios ii system board (is a custom board consist of an cyclone ii fpg...
16 years agoThis is the script generated by Eclipse nios Flash programmer.
If I launch it gives the following. Is the quartus_cpf --no_banner --convert --device=EPCS128....referred in the first lines ok ? I use an EPCS16 ? After the script finishes I press reset and programm is running ok. But if I cycle power not starts any more. I noticed also that after cycle power nios2 is absent! Thank you for your time! /cygdrive/d/ep2c8/script [NiosII EDS]$ ./flash_programmer.sh Jan 19, 2010 1:47:29 AM - (FINE) sof2flash: Starting Info: ******************************************************************* Info: Running Quartus II Convert_programming_file Info: Command: quartus_cpf --no_banner --convert --device=EPCS128 --option=D:/ep 2c8/flash/2c8_TRH_epcs.opt D:/ep2c8/2c8_TRH.sof D:/ep2c8/flash/2c8_TRH_epcs.pof Info: Quartus II Convert_programming_file was successful. 0 errors, 0 warnings Info: Peak virtual memory: 69 megabytes Info: Processing ended: Tue Jan 19 01:47:31 2010 Info: Elapsed time: 00:00:01 Info: Total CPU time (on all processors): 00:00:01 Info: ******************************************************************* Info: Running Quartus II Convert_programming_file Info: Command: quartus_cpf --no_banner --convert D:/ep2c8/flash/2c8_TRH_epcs.pof D:/ep2c8/flash/2c8_TRH_epcs.rpd Info: Quartus II Convert_programming_file was successful. 0 errors, 0 warnings Info: Peak virtual memory: 68 megabytes Info: Processing ended: Tue Jan 19 01:47:34 2010 Info: Elapsed time: 00:00:02 Info: Total CPU time (on all processors): 00:00:02 Jan 19, 2010 1:47:35 AM - (FINE) sof2flash: Done Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Resetting and pausing target processor: OK Reading System ID at address 0x00001898: verified Processor data bus width is 32 bits Looking for EPCS registers at address 0x00000000 (with 32bit alignment) Initial values: 0001703A 04C00074 9801483A 9CFFF804 983FFD1E 0000203A Not here: reserved fields are non-zero Looking for EPCS registers at address 0x00000100 (with 32bit alignment) Initial values: 92400237 4A40100C 483FFD26 90000135 92400237 4A40200C Not here: reserved fields are non-zero Looking for EPCS registers at address 0x00000200 (with 32bit alignment) Initial values: 00000000 00000000 00000260 00000000 00000000 00000001 Valid registers found EPCS signature is 0x14 EPCS identifier is 0x202015 Using EPCS size information from section [EPCS-202015] Device size is 2MByte (16Mbit) Erase regions are: offset 0: 32 x 64K EPCS status is 0x00 : Checksumming existing contents 00000000 : Verifying existing contents 00000000 : Needs erase then program 00010000 : Verifying existing contents 00010000 : Needs erase then program 00020000 : Verifying existing contents 00020000 : Needs erase then program 00000000 : Reading existing contents 00010000 : Reading existing contents 00020000 : Reading existing contents Checksummed/read 49kB in 1.1s 00000000 ( 0%): Erasing 00010000 (33%): Erasing 00020000 (66%): Erasing Erased 192kB in 1.9s (101.0kB/s) 00000000 ( 0%): Programming 00010000 (33%): Programming 00020000 (66%): Programming Programmed 144KB +48KB in 4.5s (42.6KB/s) Did not attempt to verify device contents Leaving target processor paused Jan 19, 2010 1:47:45 AM - (INFO) elf2flash: args = --input=D:/ep2c8/software/THP /THP.elf --output=D:/ep2c8/flash/THP_epcs.flash --epcs --after=D:/ep2c8/flash/2c 8_TRH_epcs.flash --verbose Jan 19, 2010 1:47:45 AM - (FINE) elf2flash: Starting Jan 19, 2010 1:47:45 AM - (FINER) elf2flash: Program Record: 71264 bytes destine d for 0x2000020 Jan 19, 2010 1:47:45 AM - (FINER) elf2flash: Start Record: 20001c4 Jan 19, 2010 1:47:45 AM - (FINE) elf2flash: Done Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Resetting and pausing target processor: OK Reading System ID at address 0x00001898: verified Processor data bus width is 32 bits Looking for EPCS registers at address 0x00000000 (with 32bit alignment) Initial values: 0001703A 04C00074 9801483A 9CFFF804 983FFD1E 0000203A Not here: reserved fields are non-zero Looking for EPCS registers at address 0x00000100 (with 32bit alignment) Initial values: 92400237 4A40100C 483FFD26 90000135 92400237 4A40200C Not here: reserved fields are non-zero Looking for EPCS registers at address 0x00000200 (with 32bit alignment) Initial values: 00000000 00000000 00000260 00000000 00000000 00000001 Valid registers found EPCS signature is 0x14 EPCS identifier is 0x202015 Using EPCS size information from section [EPCS-202015] Device size is 2MByte (16Mbit) Erase regions are: offset 0: 32 x 64K EPCS status is 0x00 : Checksumming existing contents 00020000 : Verifying existing contents 00020000 : Needs erase then program 00030000 : Verifying existing contents 00030000 : Needs erase then program 00020000 : Reading existing contents 00030000 : Reading existing contents Checksummed/read 59kB in 1.5s 00020000 ( 0%): Erasing 00030000 (50%): Erasing Erased 128kB in 1.3s (98.4kB/s) 00020000 ( 0%): Programming 00030000 (50%): Programming Programmed 70KB +58KB in 2.0s (64.0KB/s) Did not attempt to verify device contents Leaving target processor paused /cygdrive/d/ep2c8/script
