16 years agoFail to restart program after poweroff and poweron
Best wishes and happy new year for all!! I have a problem on rebooting my project. The program runs ok when flashed on my nios ii system board (is a custom board consist of an cyclone ii fpg...
16 years agoThank you all for you participation!
I used the nios ii console and tried to start the script generated by the nios flash programmer. After the script finished I see that the message in the last lines is that... ........ Device size is 512KByte <4Mbit> erase regions are: offset 0: 8 x 64K EPCS status is 0x00 Input file is too large to fit <device size =0x80000> ----------------------------------------------- I suppose I must find a way to minimize my program... .. I enabled the small C library and started again the script but the result is the same! Any suggestions?
