16 years agoFail to restart program after poweroff and poweron
Best wishes and happy new year for all!! I have a problem on rebooting my project. The program runs ok when flashed on my nios ii system board (is a custom board consist of an cyclone ii fpg...
16 years agoWell it sounds like your software is loaded into the flash but either:
1 - The FPGA programming file is not programmed into the flash. 2 - Something is failing in the configuration. Are the MSEL pins on the FPGA correctly set for Active Serial Programming? http://www.altera.com/literature/hb/cyc2/cyc2_cii51013.pdf If you have an oscilloscope handy you might want to start probing the config pins to see what is happening there. Jake
