16 years agofail to boot from norflash to sdram?
hi~~~everyone~~ I have a problem,I use the tool quartus 9.0(sp2)+ IDE9.0(sp2) to embed a nios system on my board. The Fpga device is CycloneIII.cpu clock is 100Mhz, sdram clock is 100Mhz,and pha...
16 years agothank you for your time, i have found the problem, the power supply is not correct.it is the reason why the chip of sdram is too hot.thank you very much.
