16 years agoFail comunication between DE1 and Nios EDS 9.1
I've realized via SOPC builder a working system composed by a NIOSII and various peripherals. I test it succesfully using "Altera Debug Client".
Now I would like to move to the most complete suite :"NIOS EDS 9.1", however, following the tutorial, after the compilation, when it is suggested to run: "run as , and then click nios ii hardware" This option does not apper on my sistem. and it appears only Run as Local C/C++ application I suppose that the Nios EDS 9.1 is not able to activate the communication with the board (DE1) connected via USB blaster to the USB port of my PC. Any suggestion ? Thank in advance1 Reply
Solution found:
The problem is ralated to win7 compatibility and not to the communication via USB Blaster Run NIOSII EDS 9.1 in windows XP compatibility mode
