17 years agoExternal Slave reset/clk signals
Hi all, My typical method of interfacing my Nios/SOPC system with the rest of the logic on the FPGA is to create implement one or more avalon slaves outside of the SOPC module, and to add exter...
17 years agoSomeone asked me about this the other day as well. This sounds like a bug but if you create a component that contains a file that wires the clk/reset and slave ports to a conduit that should work around the issue you are seeing. So you would just need a conduit containing signals that are in the opposite direction as the internal ports and just wire them together.
The DDR SDRAM controller connects it's I/O through a conduit just like what I'm suggesting above (except the component contains more than just wires).
