21 years agoExternal Ram doesn't show up in NIOS cpu settings
Hi All, I wanted to interface NIOS with a Cypress Static RAM instead of using the usual IDT RAM (which is present on the NIOS development board). I created a new component and specified avalon ...
21 years agoHello,
My first guess would be that when you created the interface to user logic, you chose "register slave" (or something like that), rather than "memory slave" -- this setting sets a value which the tools look at to determine whether your interface is a memory device that can be used for code, data, exceptions, etc.
