19 years agoExternal peripherals interface
Hi guys.
I'm a beginner using Nios II software and i need some advices for controlling an external camera connected to PROTO1 block in an Altera development board mounting EP2C35 FPGA. On SOPC i added a couple of PIO(??) for Ctrl bits and Data bits of the Camera,ABLE to Call IRQs. System Generation is ok,compilation is ok, software is ok , BUT: 1)If i try to read the pio ports,these are always 0 (it seems no datas eventhough the oscilloscope show datas present); 1) program stops when reach alt_irq_register(a,b,c) instruction; Have i to add an avalon tristate bridge for allowing pios's interface or it's enough to add pios on SOPC and use pin planner? Am i wrong?What have i to add? I've done the second but happen 1) and 2) Thank you very much Paolo http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/unsure.gifNo RepliesBe the first to reply
