22 years agoExternal bus interface
I'm trying to implement something similar to the MMC interface with the Nios II through DMA and/or Avalon bus. This interface consists of 1 clock and 5 bi-directional data signals. In the ...
22 years agoAs long as the NIOS is in complete control you will not need to make it a master.
So if you are simply reading and writing to this device from the NIOS then you want to use it as a slave. With that said the error messege for that one just means that a signal name doesn't follow the normal conventions used (I'm guess it's the underscore but don't quote me on that). Is "e_signal" you're own name? If so just change it to something like esignal or signalEn (depending on what it does). Like I said I don't know if that's the cause or not (because it creates signals like read_n for example by default). Try turning off the Import button, then click on generic port list then modify that to what you want.
