21 years ago###External 16 bit SRAM ### Help!
Guys and Gurus, I have a problem here... We have a board with 16 bit IDT SRAM and a 8 bit AMD Flash. We are trying to interface it with 32 bit NIOS. We have failed so far. We need help in con...
21 years agoHi Everyone,
I figured it out. You have to use the Tri-State Bridge. I was trying to interface the SRAM to the Avalon Bridge and it was just not working. I just connected my external glue-logic to the tri-state bus and it works fine. I also came across a very nice SOPC component for the same. It is posted on http://www.fpga.nl/index.html?ipcores.html (http://www.fpga.nl/index.html?ipcores.html) Guys, this coomponent is what we shall ever need. Its great. Thanks and Regards Navendujava script:emoticon(':D')
