20 years agoextern pointer C bug or not?
Is: extern cyg_uint8 gr_data_written[]; the same as? extern cyg_uint8 *gr_data_written; retrieving via { unsigned char *dp; dp = gr_data_written; my ecos gcc sets dp as th...
19 years ago --- Quote Start --- originally posted by david_cai@Oct 24 2006, 07:16 PM the question is not clear enough.
you'd better show a simple example.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=18886)
--- quote end ---
--- Quote End --- Example: // in declaration file cyg_uint8 gr_data_written[5] = {1,2,3,4,5}; --- // in this other file# ifdef FIRSTWAY extern cyg_uint8 gr_data_written[];# else extern cyg_uint8 *gr_data_written;# endif showme() { printf ("%x", (int) gr_data_written); # ifdef FIRSTWAY output of printf is a ptr "4A178";# else output of printf is the value "1";# endif ----------- I thought it was supposed to be the same either way, but it wasn't.
