20 years agoException Address Problem
I am new to using NIOS II and have run through a number of examples and tutorials successfully. I have been able to succesfully run the "Hello World" program on the "standard" example for the N...
20 years agoHi Conners,
> ... > read/write data memory heap memory and stack memory are all set to SDRAM. > This conflicts with the settings i made in builder. Is this correct? This is not a conflict. Remember, the only thing you changed was the exception address -- the address that is loaded into the PC when an exception is taken. Everything else is the same. You can continue to place all of your code/data in SDRAM -- only the exception code _must_ be located at the exception address in your SRAM. > Can anyone help me understand why this occurs and what i need to do to make my > system behave. Make sure your exception code is really where it ought to be: use objdump to confirm that your ".exceptions" section is correctly located. BTW: How do you load your application into memory? Regards, --Scott
