21 years agoExample project for Altera dev. kit and Linux
Hello all, Is there an example Quartus II project for Altera Cyclone development kit, which would be good for running Linux 2.6? Or is there any documentation that would explain how to create...
21 years agoHi, the Nios II Linux Distribution works with the standard_32 projects for each of the Altera Dev Boards. The only difference between their standard_32 and the time limited sof that we provide is the compact flash device.
So, try the standard_32 as a start point. BTW, goon is absolutely correct, don't forget to remove the ATA/IDE stuff from the kernel config before trying to build a kernel for a standard_32 project. See the reference guide for more information.
