21 years agoexample how to use a ISR at a UART?
Can some show me code where a ISR is used?
I want to go to a ISR when i recieved a char or more from a UART. I can not find example's.1 Reply
Did you check the isr routine rs_interrupt in drivers/serial/NIOSserial.c?
/* * This is the serial driver's generic interrupt routine */ irqreturn_t rs_interrupt(int irq, void *dev_id, struct pt_regs * regs) { struct NIOS_serial * info = (struct NIOS_serial *) dev_id; np_uart * uart= (np_uart *)(info->port); unsigned short stat = uart->np_uartstatus; uart->np_uartstatus = 0; /* clear any error status */ if (stat & np_uartstatus_rrdy_mask) receive_chars(info, regs, stat); if (stat & np_uartstatus_trdy_mask) transmit_chars(info); return IRQ_HANDLED; }
